Nach erfolgreicher Installation und Konfiguration mit ComSet, habe ich mit Comlist 2.4.27 ein Problem (JRE ist installiert), wenn ich das Programm starte
kommt immer folgende Fehlermeldung:
“Meldung: Die Zuordnung Gebühren/Einheit ist fehlerhaft”
- “Error: Chain of 2 or more Exception occurred”
Details sagt folgendes:
“ee com.borland.dx.dataset.DataSetException error code: BASE+47
com.borland.dx.dataset.DataSetException: Chain of 2 or more Exceptions occurred
at com.borland.dx.dataset.DataSetException.a(Unknown Source)
at com.borland.dx.dataset.DataSetException.throwExceptionChain(Unknown Source)
at com.borland.datastore.bd.a(Unknown Source)
at com.borland.datastore.nb.a(Unknown Source)
at com.borland.datastore.tb.a(Unknown Source)
at com.borland.datastore.jb.a(Unknown Source)
at com.borland.datastore.jb.createIndex(Unknown Source)
at com.borland.dx.dataset.IndexData.openIndex(Unknown Source)
at com.borland.dx.dataset.StorageDataSet.h(Unknown Source)
at com.borland.dx.dataset.DataSet.a(Unknown Source)
at com.borland.dx.dataset.DataSet.open(Unknown Source)
at com.borland.jbcl.control.GridControl.openDataSet(GridControl.java:204)
at com.borland.jbcl.control.GridControl.addNotify(GridControl.java:105)
at java.awt.Container.addNotify(Unknown Source)
at javax.swing.JComponent.addNotify(Unknown Source)
at com.borland.jbcl.view.BeanPanel.addNotify(BeanPanel.java:257)
at javax.swing.JRootPane.addNotify(Unknown Source)
at java.awt.Window.addNotify(Unknown Source)
at java.awt.Frame.addNotify(Unknown Source)
at java.awt.Window.pack(Unknown Source)
at de.auerswald.tklist.AktuellerFilterFenster.(Unknown Source)
at de.auerswald.tklist.HauptFenster.a(Unknown Source)
at de.auerswald.tklist.HauptFenster.(Unknown Source)
at de.auerswald.tklist.TKList.main(Unknown Source)
Chained exception:
java.lang.ArrayIndexOutOfBoundsException
at com.borland.datastore.oc.c(Unknown Source)
at com.borland.datastore.oc.k(Unknown Source)
at com.borland.datastore.gc.a(Unknown Source)
at com.borland.datastore.vd.c(Unknown Source)
at com.borland.datastore.vd.e(Unknown Source)
at com.borland.datastore.vd.f(Unknown Source)
at com.borland.datastore.vd.d(Unknown Source)
at de.auerswald.tklist.TKList.main(Unknown Source)”
Zwischenzeitlich kommt dann dann Abfrage der Schnittstelle (Runterladen der Gesprächsdaten beim Start des Programmes bereits aktiviert) und es folgt dann der Download der Daten ohne jegliche Fehlermeldung.
Wenn ich alle Meldung bestätigt habe, steht im Programmfenster nur die Zeile
"Column 0". Ich hatte bevor ich den Rechner neu aufsetzen musste bereits alles laufen.
Daten: Win XP Pro aktueller Patchstand AMD ATHLON 1,2GHZ
Ereignisanzeige Anwendung/Sicherheit/System zeigt keine Informationen zu diesem Thema an.
Auch das komplette deinstallieren der Auerswaldprodukte - Neustart - Neuinstalltion der Programme brachte keine Änderung bei Comlist.
Gibt es eine Lösung?
